I have problems making WiFi calls on my Samsung Galaxy Z Fold8 Ultra
1. Turn WiFi Calling on or off
- Press the WiFi Calling icon to turn the function on or off.
1. Find 'Software update'
- Press the settings icon.
- Press Software update.
- Press Check for updates. If a new software version is available, it's displayed. Follow the instructions on the screen to update the phone software.
