How to select a ringtone on your Samsung Galaxy Z Fold8
Step 1 of 8
Step 1 of 8
1. Find 'Ringtone'
Press Sounds and vibration.
Press Ringtone.
Press the required ringtones to hear them.
Once you've found a ringtone you like, press the Return key.
To use a different ringtone than the default ones, press the add ringtone icon and follow the instructions on the screen to select the required ringtone.
