I have problems using the internet connection on my Samsung Galaxy Z Fold8
1. Find 'Access Point Names'
- Press the settings icon.
- Press Connections.
- Press Mobile networks.
- Press Access Point Names.
- Press the add icon.
- Press Name.
- Press APN.
- Press Username.
- Key in o2 and press OK.
- Press Password.
- Key in p and press OK.
- Press MCC.
- Key in 234 and press OK.
- Press MNC.
- Key in 10 and press OK.
- Press Authentication type.
- Press PAP.
- Press APN type.
- Press Save.
1. Turn mobile data on or off
1. Find 'Mobile networks'
