I can't establish a connection to another Bluetooth device from my Samsung Galaxy Watch4
If you can't establish a connection to another Bluetooth device, there may be several causes of the problem.
Turn on Bluetooth pairing mode on the other device.
Check the user manual for the other device to see if it's compatible with your smartwatch.
Place the devices within 10 metres of each other.
Try establishing a connection to another Bluetooth device.
Turn on Bluetooth on the other device.
