My OPPO Find X9 Ultra uses a large amount of mobile data
1. Find 'Wi-Fi'
- Press the settings icon.
- Press Wi-Fi.
- Press the indicator next to 'Wi-Fi' to turn on the function.
- Press Wi-Fi Assistant.
- Press the indicator next to 'Auto-connect to the best Wi-Fi' to turn on the function.
- Press the indicator next to 'Auto-switch to mobile network' to turn the function on or off.
1. Find 'Notifications & Quick Settings'
- Press Notifications & Quick Settings.
- Press Manage all.
- Press the drop down list.
- Press All.
1. Find 'Location'
- Press Location.
- Press Location Accuracy.
- Press arrow left twice.
- Press Apps.
- Press App management.
- Press the required app.
- Press Permissions.
- Press Location.
- Press the required setting.
