The battery life on my OPPO Find X9 Ultra is short
1. End running applications
- To end one running application, slide your finger upwards on the required application.
- To end all running applications, press Close.
1. Find 'Location'
- Press the settings icon.
- Press Location.
- Press Location Accuracy.
- Press arrow left twice.
- Press Apps.
- Press App management.
- Press the required app.
- Press Permissions.
- Press Location.
- Press the required setting.
1. Turn mobile data on or off
1. Find 'Notifications & Quick Settings'
- Press Notifications & Quick Settings.
- Press Manage all.
- Press the drop down list.
- Press All.
1. Find 'Battery'
- Press Battery.
- Press the required low power mode to turn on the function.
