I have problems using the internet connection on my HONOR Magic V5
1. Find 'APN'
- Press the settings icon.
- Press Mobile network.
- Press Mobile data.
- Press APN.
- Press the menu icon.
- Press New APN.
- Press Name.
- Press APN.
- Press Username.
- Key in o2 and press OK.
- Press Password.
- Key in p and press OK.
- Press MCC.
- Key in 234 and press OK.
- Press MNC.
- Key in 10 and press OK.
- Press Authentication type.
- Press PAP.
- Press APN type.
- Press the confirm icon.
1. Turn mobile data on or off
- Press Data usage.
- Press Network access.
- Press the field in the "Mobile data" column next to the required app to turn the function on or off.
- If you turn on the function, press OK.
