The battery life on my HONOR 600 Pro is short
- Press the settings icon.
- Press Notifications & status bar.
- Press Manage all.
1. Turn mobile data on or off
- Press Mobile network.
- Press Data usage.
- Press Network access.
- Press the field in the "Mobile data" column next to the required app to turn the function on or off.
1. Improve battery life
- Press the low power mode icon to turn on the function.
1. End running applications
- To end one running application, slide your finger upwards on the required application.
- To end all running applications, press the end all applications icon.
- Press Location.
- Press Location Accuracy.
- Press arrow left twice.
- Press Apps.
- Press Manage apps.
- Press the required app.
- Press Permissions.
- Press Location.
- Press the required setting.
