My HONOR 400 Pro uses a large amount of mobile data
1. Turn mobile data on or off
- Press the settings icon.
- Press Mobile network.
- Press Data usage.
- Press Network access.
- Press the field in the 'Mobile data' column next to the required app to turn the function on or off.
- Press Wi-Fi.
- Press the indicator next to 'Wi-Fi' to turn on the function.
- Press More settings.
- Press Wi-Fi+.
- Press the indicator next to 'Wi-Fi+' to turn the function on or off.
- Press Notifications & status bar.
- Press Manage all.
- Press Location.
- Press Location Accuracy.
- Press arrow left twice.
- Press Apps.
- Press Manage apps.
- Press the required app.
- Press Permissions.
- Press Location.
- Press the required setting.
