I have problems receiving voice calls on my HONOR 400 Pro
1. Find 'Call forwarding'
Press the call icon.
- Press the call icon.
- Press the menu icon.
- Press Calling accounts.
- Press the name of the SIM.
- Press Call forwarding.
- Press the required divert type.
- Key in 901 and press Enable.
- Press Disable.
- Press More.
- Press Call barring.
- Press the indicator next to the required barring type to turn the function on or off.
- Key in your barring password and press OK.
