I have problems using the internet connection on my Google Pixel 11 Pro Fold
1. Find 'Access point names'
- Press the settings icon.
- Press Network and Internet.
- Press SIMs.
- Press the name of the SIM.
- Press Access point names.
- Press the add icon.
- Press Name and key in O2 UK Internet.
- Press APN and key in mobile.o2.co.uk.
- Press Username and key in o2.
- Press Password and key in p.
- Press the drop down list next to 'APN type'.
- Press default to turn on the setting.
- Press arrow up.
- Press the drop down list next to 'Authentication type'.
- Press PAP.
- Press Save.
1. Turn mobile data on or off
- If you turn on the function, press Turn on.
1. Find 'SIMs'
- Press SIMs.
- Press the indicator next to 'Roaming' to turn the function on or off.
- If you turn on the function, press OK.
