How to use split screen view on your Google Pixel 11 Pro Fold
You can use multiple applications at the same time in split screen view.
1. Turn on split screen view
To use split screen view, you need to have opened the required applications.
- Slide your finger slowly upwards starting from the bottom of the screen until the list of running applications is displayed.To use split screen view, you need to have opened the required applications.
- Press the app icon above the required app.
- Press Split screen.
- Press the second application.
- The applications are now shown in split screen view and you can use both applications at the same time.
- Slide your finger left or right on the screen to adjust the application windows to the required size.
- Slide your finger upwards on the application group.
