My Google Pixel 11 uses a large amount of mobile data
1. Find 'Notifications'
- Press the settings icon.
- Press Notifications.
- Press App notifications.
- Press the drop down list.
- Press the required setting.
- Press the indicator next to the required apps to turn the function on or off.
1. Find 'Location'
- Press Location.
- Press App location permissions.
- Press the required app.
- Press arrow left twice.
- Press Location Services.
- Press Location Accuracy.
