The battery life on my Google Pixel 11 is short
1. End running applications
- To end one running application, slide your finger upwards on the required application.
- To end all running applications, slide you finger right on the screen.
- Press Clear all.
1. Find 'Location'
- Press the settings icon.
- Press Location.
- Press App location permissions.
- Press the required app.
- Press the required setting.
- Press arrow left twice.
- Press Location Services.
- Press Location Accuracy.
1. Turn mobile data on or off
- If you turn on the function, press Turn on.
1. Find 'Notifications'
- Press Notifications.
- Press App notifications.
- Press the drop down list.
- Press the indicator next to the required apps to turn the function on or off.
1. Find 'Battery Saver'
- Press Battery and charging.
- Press Battery Saver.
- Press the indicator next to 'Use Battery Saver' to turn on the function.
