How to use GPS navigation on your Apple Watch Ultra 3
You can use your Apple Watch for navigation helping you find a certain destination.
- Press the Digital Crown.
- Press the Maps icon.
- Press the search icon.
- Press Search.
- Press the input icon.
- Press the microphone icon to turn on voice input.To use voice input, you need to turn on dictation.
- Say '[the required destination]'.
- Press Done.
- Press the required destination.
- Press the keypad icon.
- Key in the required destination and press Done.
- Press the start journey icon.
- Press the transport type icon.
- Press the required transport type.
- Turn the Digital Crown to see the suggested routes.
- Press the required route.
- Follow the instructions on the screen to go to the required destination.
- Slide your finger upwards on the screen to see an overview of the route.
- Press the end icon.
- Press End Route.
- Press the Digital Crown several times to return to standby mode.
![Say '[the required destination]'. Say '[the required destination]'.](https://cdn.sp-selfservice.com/ml/210726-f-be7dd1af-e1d8-4e96-acd3-a9c9755b5fa3.png?width=530&height=646)
