How to select FaceTime settings on your Apple iPhone Duo
You can make a video call to another device which supports FaceTime. To select settings for FaceTime, you need to activate your Apple Account on your phone.
- Press Apps.
- Press FaceTime.
- Press the indicator next to 'FaceTime' to turn the function on or off.
- Press the required setting below 'Allow FaceTime to Access' and follow the instructions on the screen to allow access for specific apps and functions.
- Press the required setting below 'You can be reached by FaceTime at'.You can select the email addresses and phone numbers others can use to contact you using FaceTime.
- Press the required setting below 'Caller ID'.You can select which phone number or email address to be displayed when you call others using FaceTime.
- Press SharePlay.Using SharePlay, you can share your screen, watch films and listen to music with others during a FaceTime call.
- Press the indicator next to 'SharePlay' to turn the function on or off.
- Press arrow left.
- Press the indicator next to 'Speaking' to turn the function on or off.You can set FaceTime to display a big picture of the person currently speaking.
- Press the indicator next to 'Live Captions' to turn the function on or off.You can set your phone to generate captions during a FaceTime call.
- Press the indicator next to 'FaceTime Live Photos' to turn the function on or off.With Live Photos, the camera takes a series of pictures of the conversation within a number of seconds allowing you to save an animated version of the screen.
- Press the indicator next to 'Silence Unknown Callers' to turn the function on or off.You can set your phone to ignore calls from people not saved in your address book.
- Press Unknown Callers.
- Press the required setting to turn the function on or off.
- Press arrow left.
- Press the indicator next to 'FaceTime Spam' to turn the function on or off.
- Press Blocked Contacts.
- Press Add Blocked Contact and follow the instructions on the screen to block a contact.If you don't want to receive FaceTime calls from certain contacts, you can block them.
