How to use notifications on your Apple iPhone 18 Pro Max
You can set your phone to display notifications about missed calls, new messages and appointments in the status bar at the top of the screen.
- Press Notifications.
- Press Scheduled Summary.
- Press arrow left.
- Press Show Previews.
- Press arrow left.
- Press Screen Sharing.
- Press arrow left.
- Press Prioritise Notifications.You can use Apple Intelligence to prioritise important and time-sensitive notifications. High priority notifications appear at the top of the notification list.
- Press arrow left.
- Press Summarise Notifications.You can use Apple Intelligence to summarise notifications so you can quickly see the information that is most important to you.
- Press arrow left.
- Press Suggestion Notifications.You can use Siri to suggest actions across different apps.
- Press the indicator next to 'Allow Notifications' to turn the function on or off.
- Press the indicators next to the required applications to turn Siri suggestions for each application on or off.
- Press the required setting.
- Press arrow left.
