How to select lock screen settings on your Apple iPhone 18 Pro Max
- Press the add icon.
- Press Add.
- Press Focus.
- Press the required focus mode.You can set your phone to use a specific lock screen with a specific focus mode.
- Press the close icon.
- Press the delete icon.
- Press Display & Brightness.
- Press Always On Display.
- Press the indicator next to 'Always On Display' to turn the function on or off.You can dim the lock screen on your phone and still have all your content displayed, e.g. background image, clock and widgets.
- If you turn on the function, press the indicators next to the required settings to turn them on or off.
