How to use the music player on your Apple iPhone 18 Pro Max
- Press the music player icon.
- Press Playlists.
- Press the new playlist icon.
- Press Create New Playlist.
- Press the text input field and key in a name for the playlist.
- Press the confirm icon.
- Press Add Music.
- Go to the required category and press the add icon next to the required audio file.
- Go to the required category or playlist and press the required audio file.
- Press the Volume keys to select volume.
- Press the song title.
- Press arrow right to go to the next audio file.
- Press arrow left twice to go to the previous audio file.
- Press the playback queue icon.
- Press the shuffle icon to turn the function on or off.
- Press the repeat icon to turn the function on or off.You can choose whether you want the music player to repeat one or more audio files.
