My Apple iPhone 18 Pro uses a large amount of mobile data
- Press Mobile Service.
- Press Notifications.
- Press Scheduled Summary.
- Press arrow left.
- Press Show Previews.
- Press arrow left.
- Press Screen Sharing.
- Press arrow left.
- Press Prioritise Notifications.You can use Apple Intelligence to prioritise important and time-sensitive notifications. High priority notifications appear at the top of the notification list.
- Press arrow left.
- Press Summarise Notifications.You can use Apple Intelligence to summarise notifications so you can quickly see the information that is most important to you.
- Press arrow left.
- Press Suggestion Notifications.You can use Siri to suggest actions across different apps.
- Press the indicator next to 'Allow Notifications' to turn the function on or off.
- Press the indicators next to the required applications to turn Siri suggestions for each application on or off.
- Press the required setting.
- Press arrow left.
- Press General.
- Press arrow left.
- Press Apps.
- Press App Store.
