The battery life on my Apple iPhone 18 Pro is short
1. End running applications
- Press Apps.
- Press App Store.
- Press Notifications.
- Press Scheduled Summary.
- Press arrow left.
- Press Show Previews.
- Press arrow left.
- Press Screen Sharing.
- Press arrow left.
- Press Prioritise Notifications.You can use Apple Intelligence to prioritise important and time-sensitive notifications. High priority notifications appear at the top of the notification list.
- Press arrow left.
- Press Summarise Notifications.You can use Apple Intelligence to summarise notifications so you can quickly see the information that is most important to you.
- Press arrow left.
- Press Suggestion Notifications.You can use Siri to suggest actions across different apps.
- Press the indicator next to 'Allow Notifications' to turn the function on or off.
- Press the indicators next to the required applications to turn Siri suggestions for each application on or off.
- Press the required setting.
- Press arrow left.
- Press Battery.
- Press Power Mode.
- Press the indicator next to 'Adaptive Power' to turn on the function.When Adaptive Power is turned on, Apple Intelligence is used to detect when your phone is using more power than usual, and automatically makes small adjustments to things like brightness and background apps so that your phone holds its charge for longer.
- Press General.
- Press arrow left.
- Press Mobile Service.
