How to select Siri settings on your Apple iPhone 17e
You can control many of the phone functions with your voice. You can call contacts from the address book, dictate messages and search the internet.
- Press Apple Intelligence & Siri.
- Press Talk & Type to Siri.
- Press the indicator next to 'Press Side Button for Siri' to turn on the function.
- Press Enable Siri.
- Press the required setting to turn the function on or off. If you turn on the function, you need to follow the instructions on the screen to set up Siri to recognise your voice.
- Press arrow left.
- Press the indicator next to 'Allow Siri When Locked' to turn the function on or off.To turn use of Siri on lock screen on or off, you need to turn on use of lock code.
- Press Language.
- Press arrow left.
- Press Voice.
- Press the required accent.
- Press the required voice.
- Press arrow left.
- Press Siri Responses.
- Press the required setting.
- Press arrow left.
- Press My Information.
- Press the required contact.When you select yourself as the owner of the phone, your phone uses your information for different voice control functions such as navigation to your home address.
- Press ChatGPT and follow the instructions on the screen to turn use of ChatGPT on or off.To use the function, you need to turn on Apple Intelligence.
- Press the required app.
- Press the indicators next to the required settings to turn them on or off.
