Operating SystemiOS 26
iOS 26
iOS 18
The battery life on my Apple iPhone 16 is short
1. End running applications
- Press Apps.
- Press App Store.
- Press Notifications.
- Press Scheduled Summary.
- Press arrow left.
- Press Show Previews.
- Press arrow left.
- Press Screen Sharing.
- Press arrow left.
- Press arrow left.
- Press arrow left.
- Press the required setting.
- Press arrow left.
- Press Battery.
- Press Power Mode.
- Press the indicator next to 'Adaptive Power' to turn on the function.When Adaptive Power is turned on, Apple Intelligence is used to detect when your phone is using more power than usual, and automatically makes small adjustments to things like brightness and background apps so that your phone holds its charge for longer. To use the function, you need to turn on Apple Intelligence.
- Press General.
- Press arrow left.
- Press Mobile Service.
