Operating SystemiOS 26
iOS 26
iOS 18
iOS 17
The battery life on my Apple iPhone 15 is short
1. End running applications
- Press Apps.
- Press App Store.
- Press Notifications.
- Press Scheduled Summary.
- Press arrow left.
- Press Show Previews.
- Press arrow left.
- Press Screen Sharing.
- Press arrow left.
- Press the required setting.
- Press arrow left.
- Press General.
- Press arrow left.
- Press Mobile Service.
