Operating SystemiOS 17
iOS 26
iOS 18
iOS 17
The battery life on my Apple iPhone 15 is short
1. End running applications
- Press App Store.
- Press Notifications.
- Press Scheduled Summary.
- Press arrow left.
- Press Show Previews.
- Press arrow left.
- Press Screen Sharing.
- Press arrow left.
- Press the indicator next to 'Time-Sensitive Notifications' to turn the function on or off.If you turn on the function, notifications from the selected app will be displayed immediately and will be visible on the lock screen for one hour.
- Press the required setting.
- Press arrow left.
- Press General.
- Press arrow left.
- Press Privacy & Security.
- Press Location Services.
- Press the indicator next to 'Location Services' to turn the function on or off.If you turn on this function, your phone can find your exact position using GPS. If you turn off the function, you can't use any GPS functions on your phone.
- Press the required app.
- Press the required setting to turn the function on or off.
- Press Mobile Service.
