How to transfer files between your computer and your Apple iPad Pro 13 (2024)
You can use WiFi to establish an internet connection.
Step 1 of 6
Step 1 of 6
1. Find 'Wi-Fi'
Press Wi-Fi.
Press the indicator next to 'Wi-Fi' to turn on the function.
Press the required WiFi network and key in the password for the WiFi network.
If the WiFi network is password protected, a lock icon is displayed next to the name of the WiFi network. You can get the password from the network provider or administrator.
Press the confirm icon.
