How to use the music player on your Apple iPad Pro 13 (2024)
You can use the music player to play audio files you have transferred to your tablet.
- Press the music player icon.
- Press the iPad icon.
- Press New Playlist.
- Press the text input field and key in a name for the playlist.
- Press the confirm icon.
- Press anywhere on the screen.
- Press Add Music.
- Go to the required category and press the add icon next to the required audio file.
- Go to the required category or playlist and press the required audio file.
- Press the Volume keys to select volume.
- Press the song title.
- Press arrow right to go to the next audio file.
- Press arrow left to go to the previous audio file.
- Press the shuffle icon to turn the function on or off.
- Press the repeat icon to turn the function on or off.You can choose whether you want the music player to repeat one or more audio files.
