How to use widgets on your Apple iPad Air 13 (M4) (2026)
1. Open widget menu
- Slide your finger right on the screen to open the widget menu.
- Slide your finger up or down on the screen to see more widgets.
- Press and hold anywhere on the screen.
- Press the add icon.
- Press the required widget.
- Press Add Widget.
- Press Done.
- Press and hold anywhere on the screen.A Smart Stack is an automatically created selection of widgets.
- Press Smart Stack.
- Press Add Widget.
- Press Done.
- Press Done.
- Press Edit Stack.
- Press Smart Rotate to turn the function on or off.Your tablet can control which widgets to display based on factors such as time, GPS position or your activity.
- Press Done.
- Press Remove Widget.
- Press Remove.
- Press and hold anywhere on the home screen.
- Press Edit.
- Press Add Widget.
- Press Add Widget.
- Press Done.
