How to select lock screen settings on your Apple iPad Air 13 (M4) (2026)
You can set several lock screens on your tablet and select different settings for them, such as background image, widgets and focus mode.
- Press the add icon.
- Press Add.
- Press Focus.
- Press the required focus mode.You can set your tablet to use a specific lock screen with a specific focus mode.
- Press the close icon.
- Press the delete icon.
