The battery life on my Apple iPad Air 13 (M4) (2026) is short
1. End running applications
- Press Mobile Data.
- Press Apps.
- Press App Store.
- Press Notifications.
- Press Scheduled Summary.
- Press the indicator next to 'Scheduled Summary' to turn on the function and follow the instructions on the screen to set the notification summary.You can set your tablet to give you a personalised notification summary at a time of your choosing.
- Press arrow left.
- Press Show Previews.
- To select notification preview only when your tablet is unlocked, press When Unlocked.
- Press arrow left.
- Press Screen Sharing.
- Press arrow left.
- Press arrow left.
- Press arrow left.
- Press the indicator next to 'Time-Sensitive Notifications' to turn the function on or off.If you turn on the function, notifications from the selected app will be displayed immediately and will be visible on the lock screen for one hour.
- Press the required setting.
- Press arrow left.
- Press General.
- Press arrow left.
