How to activate your Google Pixel 10 Pro XL
1. Enter your SIM PIN
If your SIM is locked, key in your SIM PIN and press arrow right. The default SIM PIN is 0000.
If an incorrect SIM PIN is entered three times in a row, your SIM will be blocked. To unblock your SIM, you'll need to key in your PUK. O2’s help guide will tell you how to get your PUK. Please note: If you key in the wrong PUK ten times in a row, your SIM will be blocked permanently. In this case, you need a new SIM from O2.
- If your SIM is locked, key in your SIM PIN and press arrow right. The default SIM PIN is 0000.If an incorrect SIM PIN is entered three times in a row, your SIM will be blocked. To unblock your SIM, you'll need to key in your PUK. O2’s help guide will tell you how to get your PUK. Please note: If you key in the wrong PUK ten times in a row, your SIM will be blocked permanently. In this case, you need a new SIM from O2.
- Press Accessibility and follow the instructions on the screen to select the required settings.
- Press arrow right.
- Press Skip.You can also transfer content from another phone or restore the content of a Google One backup.
- Key in the password for the WiFi network and press Connect.If there are no available WiFi networks, you can use the mobile network instead.
- Follow the instructions on the screen to finish the activation.
