Operating SystemiOS 26
iOS 26
iOS 18
How to select lock screen settings on your Apple iPhone 14
- Press the add icon.
- Press Add.
- Press Focus.
- Press the required focus mode.You can set your phone to use a specific lock screen with a specific focus mode.
- Press the close icon.
- Press the delete icon.
