How to use notifications on your Apple iPhone 17 Pro Max
You can set your phone to display notifications about missed calls, new messages and appointments in the status bar at the top of the screen.
- Press Notifications.
- Press Scheduled Summary.
- Press arrow left.
- Press Show Previews.
- Press arrow left.
- Press Screen Sharing.
- Press arrow left.
- Press arrow left.
- Press arrow left.
- Press the required setting.
- Press arrow left.
