Operating SystemiOS 26
iOS 26
iOS 18
How to turn silent mode on your Apple iPhone 15 Pro on or off
When silent mode is turned on, all phone sounds are turned off.
1. Turn silent mode on or off using the Action button
If you have not selected another preset function for the Action button, press the Action button to turn silent mode on or off.
See how to select Action button settings.
- If you have not selected another preset function for the Action button, press the Action button to turn silent mode on or off.See how to select Action button settings.
- Press Sounds & Haptics.
- Press the indicator next to 'Silent Mode' to turn the function on or off.
- Press the indicator next to 'Show in Status Bar' to turn the function on or off.You can turn display of the silent mode icon in the status bar at the top of the screen on or off.
- Press the sound mode icon to turn silent mode on or off.
